K7 1000 - ecu - GSXR.com
  • 1 Post By Winchester Boy
post #1 of 11 (permalink) Old 01-25-2019, 04:12 PM Thread Starter
Gixxerejo's Avatar
K7 1000 - ecu
Ok my buying a K7 1000 but it sat for almost 2 years without being started. Previous owner had the fuel pump fixed, but couldn’t afford to pay cost so he left the bike at the shop... fast forward, the mechanic tried starting the Gixxer and lights turn on but will not communicate with the components. He eventually purchased another ECU hoping it’ll get resolved, but I think it made it worst. PLEASE HELP!!! What do we need to do???
Gixxerejo is offline
post #2 of 11 (permalink) Old 01-25-2019, 04:44 PM
Does the bike have a new fully charged battery?
Winchester Boy is offline
post #3 of 11 (permalink) Old 01-25-2019, 04:56 PM Thread Starter
Gixxerejo's Avatar
Not sure if it was a new or fully charged battery, but Monday we are picking up a new one
post #4 of 11 (permalink) Old 01-25-2019, 05:04 PM
I wouldn't do anything until that is done.
post #5 of 11 (permalink) Old 01-25-2019, 06:45 PM
What do you mean by this? FI is blinking in the temp window (fault code)?
Please explain exactly what the bike is doing or not doing.
post #6 of 11 (permalink) Old 01-25-2019, 07:53 PM Thread Starter
Gixxerejo's Avatar
You know how when you normally turn the key to the on position, the speedometer cycles all the way then comes back to zero, it doesn’t do that anymore. The light turns on, and the speedometer is saying “check”,
post #7 of 11 (permalink) Old 01-25-2019, 07:54 PM Thread Starter
Gixxerejo's Avatar
And it wouldn’t start. Not sure if we need to re-flashed or reprogram the computer, it seems so complicated but I know there’s a simpler way to do it.
post #8 of 11 (permalink) Old 01-25-2019, 08:46 PM Thread Starter
Gixxerejo's Avatar
[QUOTE=
I wouldn't do anything until that is done.[/QUOTE]
My mechanic said he tried a new one and nothing
post #9 of 11 (permalink) Old 01-25-2019, 10:38 PM
This is normal, Try making sure the kill switch is on, pull in the clutch lever, and then try starting it. It won't crank without the clutch sensor pushed in.
post #10 of 11 (permalink) Old 01-26-2019, 05:36 AM
^ What he said.
This is normal when the kill switch is not in the "run" position (or bad), the sidestand is down and the bike in gear (or bad sidestand switch or neutral switch not working) or last, a bad side stand relay.
I strongly suggest you find another mechanic.
post #11 of 11 (permalink) Old 01-26-2019, 03:50 PM
coreyyok's Avatar
Kill Switch...lol also the new battery would be a good idea as long as it has been sitting especially if the battery wasn't maintained. When you said the tach hand didn't go throug it's self test cycle and the display says "check" the kill switch was the 1st thing that came to mind. If so and your "mechanic" bought a new ecu for that then good luck man on the rest of the bike.
Work Hard, Play Harder
coreyyok is offline
WTB K6/K7 600/750 or K5/K6 1000 ECU Pigtails ilarson007 Wanted 7 09-10-2014 10:05 AM
Formula SAE ECU hack vs third party ECU knoximator Tech and performance chat. 1 11-24-2012 07:19 AM
K6/K7 750 ECU Flashing Help MHarrisEP Tech and performance chat. 9 11-03-2012 12:27 AM
ECU on k6-600 same as a k7-750? nugent_crai Tech and performance chat. 3 06-06-2009 12:32 PM
