At a loss, bike will not turn over - GSXR.com
  • 1 Post By Racerxxxgsxr1000
post #1 of 10 (permalink) Old 03-21-2019, 10:24 AM Thread Starter
Ok guys here is my situation, sry it's so long but must explain all. I ride an 03 gsxr 600, I'm not new to this bike as I have completely replaced the motor myself and most all mechanical work. Last fall I had an electrical problem that I'm finding I still do I have replaced literally everything all new sensors, new battery starter relay, you name it I've replaced, even a brand new oem wire harness. So I replaced everything put her harness in and I go to fire it up and nothing it's like the battery is dead , I tried to look for codes with the dealer mode trick and I get nothing. I don't have headlights but I have tail lights I don't hear the fuel pump prime nor does the starter even engage. The bike ran perfect prior to all of this. I'm at a complete loss, I have researched everything and can't find anything, any advice or ideas will surely help .
bombshellrider600 is offline
post #2 of 10 (permalink) Old 03-21-2019, 10:41 AM
It sounds like you did to this bike what you did to your 750 five years ago.
You never mentioned what you did to fix the problem then, but I guess you should do the same thing.
https://www.gsxr.com/13-tech-perform...-anywhere.html
post #3 of 10 (permalink) Old 03-21-2019, 04:32 PM Thread Starter
Oh no that happened to be the main fuse under the seat, and no this time it's different I have power .
It might be my handle bar switches, I put some after market ones on that I think aren't compatible. Otherwise I have no idea so I ordered those hoping it fixes my problem.
post #4 of 10 (permalink) Old 03-21-2019, 06:20 PM
So reading between the lines, you do have power to the cluster.
What do you mean by "get nothing" when you put it into dealer mode?
The starter will crank the engine with power from the kill switch to the relay and ground for the relay through the clutch safety switch.
You say the pump does not prime so that may be another issue.
post #5 of 10 (permalink) Old 03-22-2019, 08:21 PM
"bike will not turn over" Try leaning it opposite of the sidestand, it'll turn over
post #6 of 10 (permalink) Old 03-25-2019, 10:04 PM Thread Starter
Ok so I have power to the cluster but no headlights, no turn signals,
post #7 of 10 (permalink) Old 03-25-2019, 10:06 PM Thread Starter
I bought a new clutch safety switch still waiting for it's arrival. But I should still have signals and a headlight I have a brake light just no signals and headlight.
post #8 of 10 (permalink) Old 03-25-2019, 10:12 PM Thread Starter
Also I have literally replaced every sensor switch lights oem wire harness and I am stumped. Will the speedometer keep the lights from working? Help
post #9 of 10 (permalink) Old 03-26-2019, 09:16 AM
Sounds to me like a bad fuse, bad connection in the ignition plug, or bad ignition switch. I would look at, and test all these things, in that order...
post #10 of 10 (permalink) Old 03-28-2019, 04:44 PM Thread Starter
When you say ignition switch do you mean where you put the key into. Its brand new as well except I did get a bad brand new one I just happen to have a new one I can try that. I did get my new switches but I'm waiting for a new clutch safety switch as well I haven't replaced that yet. It should be here tomorrow .
NEED HELP! Bike will NOT turn over. Tyler Sinquefield Tech and performance chat. 5 06-07-2018 05:53 AM
1995 gsxr 750 will turn over but not start slwj99 Tech and performance chat. 1 06-24-2010 04:29 AM
2001 750 will not turn over!!!! help please!!! Keeb Tech and performance chat. 11 11-23-2009 02:30 PM
k2 1000 gsxr would not turn over ramashkaus Tech and performance chat. 3 05-08-2008 01:21 PM
