K1 750 map sensor - GSXR.com
post #1 of 7 (permalink) Old 05-11-2019, 03:09 PM Thread Starter
K1 750 map sensor
Hello i need help to connect this sensor on the vacuum ? Thanks
Screenshot_20190512-000728_1557612463934.jpg   Screenshot_20190512-000713_1557612486554.jpg
Kushosv650s is offline
post #2 of 7 (permalink) Old 05-11-2019, 05:04 PM
Welcome.
This should be in the Tech section not the site issues.
I can't be sure, but I think that is the ambient air pressure sensor and is just open to the atmosphere. Otherwise, it is not connected to anything.
The only way to confirm that is by posting the colors of the wires going to it.
Any reason you think it should be hooked up to something?
post #3 of 7 (permalink) Old 05-11-2019, 05:53 PM
Originally Posted by rv6john View Post
Welcome.
I agree, it's in the tail section, and it doesn't have anything connected to it other than the wires. It's the same as the airbox sensor which does have a vacuum hose running to it. It just reads the air outside.
post #4 of 7 (permalink) Old 05-12-2019, 03:33 AM Thread Starter
I had yamaha xt660x and it had this kind of sensor and was attached to the hose and did not want the engine to work without it. The other sensor is connect 😀
post #5 of 7 (permalink) Old 05-14-2019, 05:18 AM
That would be the IAP (intake air pressure sensor). You also have one and I believe it will be under the airbox somewhere. So you have two of the same sensor on your GSXR used for different purposes.
post #6 of 7 (permalink) Old 05-14-2019, 06:19 AM
They are similar sensors but not the same exact ohm measurements long story short they are not compatible to swap your bike won’t run correctly , ones mounted to the air box ones under ur tail.
post #7 of 7 (permalink) Old 05-14-2019, 04:14 PM
Its def. the IAP, and the vacuum line connects to the sensor on one end, while the other end is definitely left open. I just replaced one on my k1 750.
Jim Delaney is offline
K1 - IAP sensor vs. MAP sensor? 6Gears1Speed Tech and performance chat. 6 08-13-2013 07:08 AM
Tip Over Sensor... (TO Sensor) Hypa Tech and performance chat. 18 09-20-2012 06:42 PM
Need a CkP sensor ( Crank Shaft Sensor ) Chris06stg2 Wanted 0 03-15-2011 09:10 AM
Where are the TPS/Speed Sensor/RPM Sensor? xluryan Tech and performance chat. 10 04-30-2010 07:30 AM
WTB MAP sensor for 2005-06 1000 audi1031 Wanted 3 08-30-2008 10:35 AM
