Help! - GSXR.com
post #1 of 6 (permalink) Old 07-23-2019, 07:50 PM Thread Starter
Lovetoride's Avatar
Help!
2002 GSXR 600 charging issue.Brand new OEM Stator and rectifier.Wires get extremely hot once I start the bike.This seems to be a common issue.Any advice?
Lovetoride is offline
post #2 of 6 (permalink) Old 07-24-2019, 11:05 AM
Check out the plug coming off the stator that plugs into the harness of the bike a lot of times they melt and could cause a poor connection.
PaulPhilly is online now
post #3 of 6 (permalink) Old 07-24-2019, 12:05 PM Thread Starter
Lovetoride's Avatar
It was melted, I'm currently replacing wires, soldering the connections instead of using the snap in connectors
post #4 of 6 (permalink) Old 07-24-2019, 06:45 PM Thread Starter
Lovetoride's Avatar
After replacing some of the melted wire, using the new connectors instead of the Molex, replacing the stator and the rectifier it's now charging at 14.7 at idle and 14.2 at 5000 RPM' S.Any thoughts?
post #5 of 6 (permalink) Old 07-25-2019, 07:30 AM
Those are normal readings, sounds like you got it fixed.
Hopefully, you installed quality products and not Chinese crap and you used loctite on the stator bolts.
post #6 of 6 (permalink) Old 07-25-2019, 10:12 AM Thread Starter
Lovetoride's Avatar
I bought OEM parts from the "stealer"ship and I torqued the stator bolts but I did not use loctite.Fingers crossed
