Gear shift help please - GSXR.com
post #1 of 6 (permalink) Old 07-30-2019, 01:20 PM Thread Starter
10q
Hi I’m new in here so please sorry if I post not in write place
My problem is
Gsxr 600 srad 1999
Won’t shift in 3rd gear and up while riding
But when it’s parked and non runing gear shift go all the way up and down
I been told it’s clutch plates, replaced them still doing same thing I’m confused now
Thanks
10q is offline
post #2 of 6 (permalink) Old 07-30-2019, 01:35 PM
Welcome.
The tech section would have been the best place.
So it goes down into 1st OK and you can shift to 2nd OK, but what does it do when you try to shift to 3rd and up?
Does the shift lever not move at all?
Have you checked that the shift lever or shift rods are not hitting anything on the up shift?
post #3 of 6 (permalink) Old 07-30-2019, 02:29 PM Thread Starter
10q
That’s the problem it’s don’t move up any more and shifter dot hit anything
Couple weeks ago was like reach 5th gear and won’t go down les then 4th gear or reaching 4th don’t go lower then 3th
On last my ride last Friday it’s wont go up after 2nd gear so I replaced Clutch plats as recommended from garage but still got problems
10q is offline
post #4 of 6 (permalink) Old 07-31-2019, 09:29 AM
Sounds like a bent, or broken shift fork to me... When it is NOT running, you can shift up INTO higher gears? Are you sure it is actually shifting to 3rd+ while not running? Try shifting it to 3rd, and then start the bike, and try to move by letting the clutch out a bit. Does it move? Does it make any noises?
post #5 of 6 (permalink) Old 07-31-2019, 10:19 AM Thread Starter
10q
I can shift up gears to roll a bike a bit forward and back but it’s not easy as should be any way
If that’s a forks i need take engine out of frame ? :((
10q is offline
post #6 of 6 (permalink) Old 07-31-2019, 10:22 AM Thread Starter
10q
Also I can’t find that star bolts or whatever it’s call where it’s should be cos I read it’s my that problem if that star bolt is loose
10q is offline
