H9 LED High Beam - GSXR.com
post #1 of 9 (permalink) Old 06-05-2019, 01:44 PM Thread Starter
H9 LED High Beam
I was always worried about replacing the H9 High beam for an LED bulb as the original almost touches the steering damper on my K7 1000, and as Gixxerboys sell an LED H9 for about 80 I thought it was a special order, turns out they are just trying to con you
I put an H7 Led in a while ago and was very happy with it, so when I got the chance for a free pair, I couldnt say no.
It turns out the LED H9/11 is shorter than standard so its not a problem touching the steering damper, and its a lot brighter than standard. I bought/reviewed the one in the link, but im guessing any will fit. If you click the link you will see the video I took on the review.
Yam FS1E
Hon CB100
Hon CB200
Suz X7
Suz GS550E
Suz GSX750
Yam 350YPVS
Hon VFR750
Yam RD350
Kaw GT550
Kaw ZZR600
Yam FZ1S
Suz Burgman 650
Hon VFR1200
Suz GSXS1000F
Suz GSXR1000 K7
R1KSU is offline
post #2 of 9 (permalink) Old 06-05-2019, 06:25 PM
I know my k6 came with a 9005 high beam hid when I bought it the only reason I know is bc I had to replace the ballast. First pair of hids I’ve ever owned . It seems to work fine it’s bright as hell accually I like it besides replacing the ballast. I got leds in my truck and they are bright but don’t compare to the hid.
post #3 of 9 (permalink) Old 06-05-2019, 11:02 PM Thread Starter
Good to know. My original high beam bulb snapped as I was taking it out, so the glass is still inside the headlight, nightmare to remove the headlight.
Yam FS1E
Hon CB100
Hon CB200
Suz X7
Suz GS550E
Suz GSX750
Yam 350YPVS
Hon VFR750
Yam RD350
Kaw GT550
Kaw ZZR600
Yam FZ1S
Suz Burgman 650
Hon VFR1200
Suz GSXS1000F
Suz GSXR1000 K7
R1KSU is offline
post #4 of 9 (permalink) Old 06-06-2019, 12:41 PM
Try a shop vac duct tape a smaller rubber hose on to the shop vac hose small enuff to fit in the opening for the light big enuff to suck the glass 1/2” maybe 7/16” probally
post #5 of 9 (permalink) Old 06-07-2019, 10:06 PM Thread Starter
There is no room behind the headlight to do that sort of thing unfortunatly
Yam FS1E
Hon CB100
Hon CB200
Suz X7
Suz GS550E
Suz GSX750
Yam 350YPVS
Hon VFR750
Yam RD350
Kaw GT550
Kaw ZZR600
Yam FZ1S
Suz Burgman 650
Hon VFR1200
Suz GSXS1000F
Suz GSXR1000 K7
R1KSU is offline
post #6 of 9 (permalink) Old 06-08-2019, 03:01 AM
Take the windsheild off, then use the hose from the vac, I’ve never been behind a k7 light I got the room on the k6 for a smaller hose
post #7 of 9 (permalink) Old 06-08-2019, 08:48 AM
Your headlight is not designed for LEDs or HIDs, do not use them.
post #8 of 9 (permalink) Old 06-09-2019, 08:09 AM
lookatme's Avatar
Interesting that you say this, can you tell me exactly why we can't use LED or HID lights?
lookatme is offline
post #9 of 9 (permalink) Old 06-15-2019, 08:37 AM
Because your headlight was not designed for it. The focal pattern is designed for a halogen bulb. This means your light dispersion is going to be all over the place. An HID bulb illuminates the entire bulb, while LEDs do not have the same distances from the mounting point as a halogen.
