msd launch control installation help - GSXR.com
post #1 of 3 (permalink) Old 05-10-2016, 01:02 PM Thread Starter
13btoy's Avatar
Hey guys I'm installing an msd 4350 on my k6 1000 and need help wiring it to the clutch switch. Can someone please tell me which wire to tap into?
Thanks in advance, Ed
13btoy is offline
post #2 of 3 (permalink) Old 05-11-2016, 12:09 PM Thread Starter
13btoy's Avatar
Nvm guys I figured it out. For future reference and for those of you looking to install one of these, the wire you want to tap into is the black and yellow. If you look at your clutch switch there's a black and yellow wire coming out of it. Follow this down and it should bring you to a yellow connector in front of the air box. Tap the blue
Wire from the launch control to this yellow and black wire for your clutch activation. Hope this helps!
13btoy is offline
post #3 of 3 (permalink) Old 05-26-2016, 07:55 AM Thread Starter
13btoy's Avatar
Btw you may want to add a toggle switch. This way you can turn it on and off. What I did was put a switch in line of the clutch switch. This should be the blue Wire on the msd.
13btoy is offline
