Drive chain tension!!!! - GSXR.com
post #1 of 3 (permalink) Old 04-10-2019, 10:18 PM Thread Starter
I have a 1993 GSXR 750. Unfortuantely it seems that my left side drive chain tension-er has the threads stripped out within the swing-arm. I cant keep the chain tight enough so have not been able to ride for a few days. Has anyone had this issue and if so how did you fix it. Is there a vendor that sells aftermarket tensioners for that year 1993. So far I have not been able to find any. Thanks for your help in advance.Xvideos Xnxx Chaturbate
viprit is offline
post #2 of 3 (permalink) Old 04-10-2019, 11:41 PM
Put another Nut on the tensioner bolt to hold it in place and then lock them together. It won't last forever, but It'll get the job done for a year or two. I'd talk to a machine shop about getting it drilled out and a heli-coil put in the swingarm because that's going to pretty much be your best option for a permanent fix.
post #3 of 3 (permalink) Old 04-11-2019, 05:36 AM
That is strange old tensioner.
The good part is that both stud and special nut are still available from Suzuki for less than $20.
This is the parts list for the adjuster. If you need the stud also you will find it listed under "rear swing arm"
https://www.cyclepartsnation.com/oem...-wheel-model-p
Drive chain tension mithrander Suspension and Tire Tech 1 09-22-2015 04:27 PM
chain tension varies mcbull Tech and performance chat. 3 09-19-2006 06:47 PM
Reinstalling Cam chain tension adjuster gsxrm02 Tech and performance chat. 3 09-15-2006 08:12 PM
cam chain tension adjustment ogx3og Tech and performance chat. 19 04-23-2006 12:32 PM
Specific GSXR chain tension question UltimatE Tech and performance chat. 2 03-31-2006 12:54 PM
