1 - 1 of 1 Posts
Selling my 2002 GSXR 600...
No title, BOS only
Located in NJ
3000.00
2002 GSXR 600
Hotbodies fairings.
Fairing Stay
Lockwired
Lindeman tuned forks (02 is conventional fork)
Ohlins rear. (Im 175 pounds geared up )
Vortex rearsets
Vortex rear master return spring
Vortex folding toe shifter
520 chain and sprockets RK, Vortex (6 TD on them)
Zero G screen
Keyless Ignition
Giannelli pipe (some fraying heat wrap where fairing rubs pipe)
CF muffler bracket
Shorty Chinese levers
Battery tender hook-up
Ohlins damper
SS lines
Lightened rear rotor
Vesrah RJL pads (8 TD on them)
Dunlop Q3+ tires (2 TD on them)
90 degree valve stems
Bel-Ray oil and brake fluid (oil changed after TD weekends) Brake fluid changed when I got it and once since)
I used premium gas station fuel (Sta-bil atm)
Currently has anti freeze. I used water wetter/dw for track duty.
Comes with:
Both stands.
Set of slicks used by former owner (Old)
Wheel set with rotors and cush
Fully painted unmounted spare set of body work. (Upper, lower and tail section) Hotbodies. Couple of spare fasteners
Odds and ends levers, rearset parts, a usable sprocket or two (Stock,TCM , front and alloy rear 15/46 )
NRC starter clutch cover and gasket
Graves idler gear cover and gasket
295761
1 - 1 of 1 Posts
