so i installed aux lights on the bike. worked and went out.
cluster lights went out and the plate lights went out. head lights work perfectly. bike starts up. sooo ideas? ready set go
It sounds like you blew the "signal" fuse. I'm guessing your horn does not work either.
The horn doesn’t. Checked the fuse. All fuses are intacted.
Check again. They can have a very fine crack that is hard to see. You can also check the fuse with and ohmmeter.
If you are 100% sure the fuse is good, it's time to get out a wiring diagram and test light and see where you are losing power.
