1 - 3 of 3 Posts
I'm in need of a 04 gsxr 1000 engine..or if there is any other models that would fit my 04 frame...
Well,
Not sure if you've looked on FeaBay, I haven't.
For the 1000, the 03-04 is the same bike/platform exactly. They changed a tiny bit every 2 years, with that bracket,
LIke the 05/06 are identical other than a few decals.
So any 03/04 should be a direct pug and play.
Good luck.
BTW, what happened you your motor?
The upper engine mount changed over the years as the mounts were moved from the head to the crankcase. I seem to recall that some have used a K5/K6 and left one upper mount empty. That sounds rather iffy. Hybidracing.ca sells an adapter kit for K5/K6 into K1/K2. Perhaps it will work on yours. But K5/K6 is big step as all the electronics will need to be updated. Suggest that you look for a K3/K4.
1 - 3 of 3 Posts
