1 - 3 of 3 Posts
Ok, this is the problem I am having and maybe someone can help me figure this out before I shoot myself. I have a 04 gsxr 1000 that I bought as a salvage. I have the bike repaired and running strong! Everything is good, but my left turn signal will not work? The right turn signal works fine and the hazards work on the right and both rear signals. I checked the wires in the switch and everything is fine so I checked for voltage where the left turn signal wires plug into the wiring harness plug and I am getting no power there? I should have constant power there when the hazards are on right?? I have a wiring diagram, but not having much luck with it...Does anyone have a clue what to check? I figured since the right turn signal was working it can't be the fuse or relay.
Any help would be greatly appreciated.
1 - 3 of 3 Posts
