1 - 15 of 15 Posts
I am in need of the wire diagram for an 05 gsxr 1000....Yes I know I can buy the book , but what better than you helping your peep`s out. Anyone with suggestions or the book you could send me a burn of that page.....anything helps. Trying to wire up my 05 SRAD Hybrid...........
· Premium Member
Which part your trying to wire up? You should use the switches from the 05 1k.. It would save you the trouble and the Rectifier your gnna need to pick one up also you should check to make sure your airbox clearance would be fine. I have the PDF for you but not sure how to send it. You need to grab a 05 Fuel pmp. Your in ATX hit me up I can put it on a flash drive bring it to you
You can download the manual online. The proper schematic is the E-03 for USA except california. Free just do your search and browsing. I can't post the page because to be readable it is past the width and heght range but not past the file size range. Just use K6 1000 service manual .pdf as you search term. Yo can even use advanced searc to limit results to only pdf files. Make yourself happy.
Well Mr. Audi... I just want to be sure im putting plugs and connectors at the right spots... I do have 05 clip ons and fuel pump for the 05 and rectifier for the 05 . I f you dont mind sharing , You can send it to my yahoo account, i can send you my address to you via a personal message on this site and you can send on if thats cool with you...
· Premium Member
White connectors up top black ones below on the injectors also there is not sensor on the radiator like previous bikes.
I cant send it via email but yo can download from the site on here to your computer. So you went with the 05 1k GFood choice there and be sure to make it look right as in Stock appearance.
Discussion Starter · #9 ·
Alright Audi nice pics..yes sir I am putting it back stock as possible seeing the age gap . But thats why its taking me so long...but it should be worth the wait. Well im gonna see if i can down load the pdf to computer....Thanks for all the input. Hey if u got more pics send them on.
· Premium Member
You would have better luck with using a 00 and up speedo than the Srad speedo on doing your project. If i was you I would use the 05/6 1k speedo to get it to work.
1 - 15 of 15 Posts
