Curious to see hear input as to what could be going on...
Came in after 1st session on track, bike stalled coming into the pit with clutch pulled in. At low RPM it stumbles/stalls when trying to start and after running for a minute or so it would shut off. No discernible loss of power on track on wide open throttle or at high RPMs. Anything above 4-6K it is running just fine. As the day went on, it got worse and eventually sounded like it wasn't firing on all cylinders when idling (going back and forth b/w 3 and 4 cylinders). Tried to start the bike again this morning (5 days later) issues still persists which is actually a good thing from a diagnosis standpoint. Currently at 14,220 miles on odo. so I am due for a few major service items, planning on going through the bike entirely and getting it up to date on all its maintenance under this service interval.
Current plan:
All that said.. am I missing anything? Something else I should be looking at? Am I on the wrong track with any of this?
RE the valve clearance check and adjustment... I found and bought a Suzuki factory service manual off ebay a year or so ago (it is for an 04 GSX-R 750 - but the specs are essentially the same) and someone has an excellent write up for the valve clearance check so b/w those two I think I have the information I need. It is definitely daunting but I would like to learn to do this myself and not rely on the dealer.
Current plan:
- Check for any codes
- Remove existing spark plugs and check for spark
- Wrap stick coils in electrical tape (looking for faulty stick coil that could be breaking down and arcing on the head within the spark plug bore)
- Replace spark plugs (14K service interval)
- Check fuel injectors for optimal flow (thought is that at high RPM's there is enough pressure to ensure fuel flow but at low RPM pressure is not able to be maintained and engine is stalling)
- Check and replace fuel filter
- Mix and run fuel injector cleaner in fuel
- Swap MAP and air pressure sensors (rule out failing sensor)
- Check valve clearances (adjusting if necessary)
