Alright, John (
rv6john) and I jumped on a call for a bit today, super helpful guy and I appreciate his time talking through this.
To bring this thread up to the most current situation:
1. The engine stumbling/stalling and not firing on all 4 cylinders was resolved once the spark plugs were replaced.
2. The current issue (which the last few posts involving the crankshaft and camshaft position sensors are in reference to) is as follows:
A. After riding continuously for ~1.5 hours the engine will suddenly cut out with little warning.
B. It will crank continuously if I try restarting it and if it does start it will, in most cases, not stay running for more than 30 seconds or unless I give it throttle to keep the RPM's up
C. It seems that after sitting for 5-10 minutes it will restart and run as if nothing is wrong but the issue will come back after a few minutes of riding.
D. Every time this occurs I have noticed that the fuel pump won't prime and neither will the fuel pump relay click when the engine stop/start switch is flipped. However, after sitting for a few minutes it will usually come back and the bike will start or attempt to start.
Currently, the dealer is running diagnostics on the bike and checking over some sensors. I will probably be doing another test to failure this Friday to see if the issue is resolved based on what they find this week and what repairs (if any) they make.
