1 - 3 of 3 Posts
can someone tell me if something important connects to the rear electrical connectors? the reason im asking is because the 3 part connector, the wire colors are faded and i dont want to ruin anything if i plugged it the wrong way.
Hard to say from your post. There are a couple of normally open connectors in the battery area and there might be more aft if the EXCA actuator is removed or the old tag light connector.
The wire colors are the key to figuring out what the connector is used for. Since your wires are faded, I'm wondering if it is from some aftermarket part. I've not seen the Suzuki wires fade so much that you could not tell tell the colors but I have not seen everything.
1 - 3 of 3 Posts
