1 - 20 of 31 Posts
Just wondering if anyone had any stats on 1/4 mile times of the gsxr 600,750,1000, and 1300. Or anyone that's run thiers at the track ok nevermind i got to looking and found what i wanted sorry for the post mod you can close it
I went with the katana are the times that much off it's an 04 600
It is going to be considerably slower than the 600 times. Less power with more weight.
I'll never take it to a track just would like to have the bragging numbers for my car driving buddies but i'll look it up should be able to find it online somewhere.
you should still be able to beat a lot of cars out there, look in the back of some of the bike magazines, they usually have that info in them.
bad 750
my 91 gsxr 750 ran a 10.23 at 130 wit 1100 cams lowered and sidewinder.... witout hookin up and short shifting 2nd gear.. runs iiiiiight.
I pulled a 12.4 with my stock 01 katana, you should be able to get right around there.
Discussion Starter · #11 ·
im guessing you are talking about the gsxr. So I should be able to pull 12's all day thats straight..... for now.
New to the strip (humbling learning experience!) no 1/4 tracks here just a 1/8 mile. Slammed and stretched 3" and 15lbs in the rear no more wheelies and spinning now. Nothing to brag about on times yet, launching from a stand still on a sticky surface is a long learning curve.... Best has been 6.9. Another rider (235 lbs) 2nd time running it ran 6.6's. Will eventually get the times down, just takes lots of practice. Bike has the hp for low 6's but picks up on the back end of the 1/8 and turns high mph for the times. 1/4 track would be better suited but need a NHRA license to go over 120 at Gainesville.
THESES ARE 1/4 MI TIMES OFF OF SPORTRIDER.COM.THESE ARE ALL STOCK BIKES RIDIN BY PRO RIDERS. :thumbup:
Suzuki
motorcycle issue quarter mile
(sec. @ mph) 60-80mph
time (sec.) 80-100mph
time (sec.) top speed
(mph)
GSX-R600 ('97) 4/97, 12/97 11.09 @ 124.0 5.17 5.5 151.5
GSX-R600 ('98) 8/98 11.20 @ 123.17 4.44 4.77 150.7
GSX-R600 ('99) 6/99 11.15 @ 123.20 4.68 5.06 153.1
GSX-R600 ('00) 10/00 11.13 @ 122.79 5.27 5.77 148
GSX-R600 ('01) 2/01, 12/01 10.80 @ 125.40 5.33 5.84 157
GSX-R600 ('01) 6/02 10.74 @ 127.06 4.79 5.33 157
GSX-R600 ('03) 6/03 10.80 @ 127.8 5.36 6.51 158.8
GSX-R600 ('04) 6/04 10.58 @ 130.5 3.76 3.86 n/a
GSX-R600 ('04) 8/04, 10/04 10.65 @ 128.8 4.06 4.31 n/a
SV650S ('04) 12/04 12.02 @ 108.9 5.24 5.71 n/a
GSX-R750 ('96) 12/96, 12/97 10.54 @ 133.5 4.96 5.17 163.6
GSX-R750 ('98) 4/98 10.54 @ 131.0 n/a n/a 162.2
GSX-R750 ('98) 12/98 10.54 @ 131.0 4.46 4.57 160.9
GSX-R750 ('00) 8/00, 12/00 10.26 @ 135.6 4.11 4.34 172
GSX-R750 ('04) 8/04, 10/04 10.36 @ 135.4 3.67 3.86 n/a
RF900RV ('97) 2/98 11.05 @ 123.4 4.63 4.95 n/a
GSX-R1000 ('01) 6/01, 12/01 10.10 @ 141.70 2.73 2.79 179
GSX-R1000 ('02) 8/02 9.92 @ 144.96 2.83 3.01 177
GSX-R1000 ('03) 8/03, 12/03 10.09 @ 141.45 2.7 2.89 n/a
GSX-R1000 ('04) 6/04 9.96 @ 144.7 2.64 2.78 180
TL1000S ('97) 6/97 10.84 @ 128.4 2.99 4.67 n/a
TL1000R ('98) 10/98 10.76 @ 129.14 4.3 4.74 n/a
TL1000R ('98) 12/98, 6/00, 10/00 10.75 @ 130.21 4.3 4.74 163.8
SV1000S ('03) 8/03 10.82 @ 127.1 3.79 4.51 n/a
GSX-R1100 ('97) 10/97 10.45 @ 130.2 4.78 4.9 163
Bandit 1200S ('01) 8/02 n/a 4.08 6.3 n/a
GSX1300R Hayabusa ('99) 8/99, 12/99 9.97 @ 144.80 3.28 3.47 189.6
GSX1300R Hayabusa ('01) 10/02 10.237 @ 140.54 n/a n/a 183.9
top
Those are all also CORRECTED Times.
does anyone have 0-60 times? I'm looking especially for the 00 750's.
corrected to reflect what the bikes SHOULD theoretically run at sea level. If they are riding at a high elevation the air pressure is less and the egine won't be running quite as well as it would at lower elevation with more pressure.
I'm not sure how they calculate those times though. :hmmm:
Less said:
what do you mean by corrected?
Corrected, means they take the actual time it took the rider to make it from start to finish, and then make calculations including elevation, wind speed and I think temp. , and the time they give you is what the bike should run in optimal conditions at sea level. They are not actual times.
1 - 20 of 31 Posts
