1 - 3 of 3 Posts
Went to go for a ride yesterday and the carbs just started leaking petrol right after I filled it up from the base of them.
Just had the bike serviced and they done heaps of work on the floats and gaskets as well.?????????:headscrat
Check your petcock make sure its not in the PRI postion, this is a Primer that pours gas into the carbs for cold starts and if you leave it on "PRI" it will fill the carbs and your crankcase with gas.
If you filled your tank too full the gas could be coming out of the tanks vent tube making it look like the carbs are leaking?
If thats not the case maybe the "guessed" at the float level? Are all 4 carbs leaking the same?
1 - 3 of 3 Posts
