Hi All :hello:,
As stated in my first post I have just bought my first proper bike a (1998 - GSXR 600). I’m new to the whole motorcycle scene, so have a couple of questions that you might be able to answer for me with regard my bike (they will sound silly to you but like I said, I’m new to bikes).
1. How many gears does my 98-GSXR 600 have?
The web research that I have done says six but I’m not sure as I have only ridden it a couple of times and it doesn’t seem like I’m accessing any more than 4 or 5. Also, is neutral classed as a gear when referring to this subject? I have been paying more attention to the road at the moment rather than the bike, till I get used to it more anyway.
2. At how many RPM’s should I be changing gear at? I’m currently changing between 3000 – 3500, is this right?
I understand that when riding at excessive speed then the RPM’s will be much higher but I’m referring to standard speed limit riding.
3. The guy I bought the bike from said that the bike is air cooled but thought I would double check with you guys, just in case I should be adding water?
4. The oil in the little window of the bike is black and seems very runny. I thought that it should be a yellow/treacle type colour and texture. Do I need to do an oil change? And if so, how do I go about doing this? Is there a step-by-step guide online that I can follow that explains how to do it and how much oil I will need?
Answers to the above questions would be much appreciated from anyone who has time to reply.
Apologies once again for the questions being so noobish for you guys to answer.
Thanks
Phibir :bike:
Thanks
Phibir :bike:
