Ok, i have tried to adjust the TPS sensor for awhile now. Tried to connect the plug, start her up,nothing. Then i was reading something about a power commander. So i unplugged the power commander and bypassed it. Same thing. Any ideas? What Is the correct procedure to adjust that thing..
thanks and aloha
Darin
When you said tried to connect the plug you do mean the wihte connector under the rear seat just loop this connector set tick over at 1000 +- 500 rpms loosen tps set your display to the center mark.
Increase rpms to 1800 2000 it should go to the higher mark.
