Can someone explain the secret to compress the clutch spring in order to install the 3 little screws that hold the clutch spring holder in place. I am not having any luck.
Thanks
Thanks
This is a very good post.I’ve had more than a few clients bring me their bikes to figure out why their clutch either isn’t going back together as expected, or fails to work after having been reassembled. Often times it is a stacking issue, and mostly the mistake is the last piece to go in over the stack, it has grooves just like the steel plates in the stack. When u install this piece, need to be sure the grooves mate properly with the splines. During the installation of this part turn it slightly back and forth until u feel it slip into the splines, if you can’t get them to line up, remove the part and turn it generously to match up the spring perch holes with the next threaded receiver and try installing it again, there shouldn’t be any gap between the outermost friction plate and this part.
