Hey everyone I’ve been on the site for about a year now but this is my first post, i’ve had electrical problems with this bike since the beginning I replace the regulator rectifier, the stater the battery a couple of different fuses and I’m still running into electrical problems and idk what to do, The electrical connection to the stater has resistance coming from somewhere because it’s partially melted and this isn’t the first time the stater that I replaced was just like this the guy before me I have no clue what he did to the electrical system but it seems changed when I compare it to the OEM wiring diagrams. Here’s a couple of pictures
Two options;
i) with your ohmmeter and several hours, mark each of the connectors, and then painstakingly draw out the circuit that is currently on your bike, noting the resistances between the various connections (not just 'connected'), then compare it with what it should be and fix the differences/high resistances,
ii) let someone else do that, either professionally in a workshop (most expensive option) or by means of providing you the correct harnesses.
I don't believe there are any other options involving beer, pliers and a screwdriver, and/or wishful thinking.
I can't imagine how the bike ended up in that state so I doubt anyone would be able to identify some 'underlying cause' that could fix it.
Probably 10 different owners each bodging the circuit in their own peculiar ways.
Start again.
