1 - 3 of 3 Posts
Hi
I pulled the codes and got a C24 and C25 code.
New stator + rectifier
New plugs and coil pack
TPS checked
Any advice or suggestions?
Is the bike only running on 2 cylinders?
Did you only replace one coil stick or both?
Did you try swapping a coil stick from cylinder #1 or #2 to #3 or #4 to see if the problem travels to that cylinder?
Yeah i swapped 1 to 4 and it still throws the code. Ive checked the connectors to see if theres corrosion, but didnt have any luck
1 - 3 of 3 Posts
