First off what's up people? Sencond thanks for looking at my post.. Hope someone can help me out. Ok here is the problem.. My bike is bogging down at high rpms, (10 1/2 to be exact). When you try to give it gas past that mark it will not go. Just bogs it down. I thought it may have been the injectors so I put a couple stp additive (about 1 per fill up, 3 times) and on my last time around I put SEAFOAM. Still no improvement. The bike seems to
have cold starts, it takes anywhere from 5-9 times starting it for it to start running. And it kinda is running rich like when you are first starting it. Once it starts up the bike won't run right till it hits about 150 degrees. Kinda hard to explain bit the colder my bike is, the less rpms I can get it up to, and the max I can do is 10 1/2 @ about 150 degrees (maybe more, from 120-170 it jumps pretty fast, as a normal bike would). I do not have a power commander or anything like that installed on my bike. Can anyone help me out? Ask questions and I'll answer it the best I can. Thanks.
