Hi all, this is my first post so hoping you all can help.
I've got a 2002 GSXR 600 K1, which I've owned for a year or so and has had issues with the battery draining for most if not all of that time. I originally noticed that when riding, the speedometer/gauges would switch off and the revs would drop to 0 before then restarting and jumping straight back up, the whole time the bike would continue running though. I thought it was related to the headlight as when I turned the headlights off, it seemed to stop. I noticed there was a 100w bulb in so swapped it out for a 55w one. Anyway, that didn't stop it from happening still and it continued to happen whether the headlight was on or not. The bike still run and it didn't turn the lights off etc. so I just lived with it.
The battery draining is the big problem though...I can leave the bike for just a day or two and the battery will be dead. I recharge the battery and the bike starts up fine. I bought a new battery and the same thing keeps happening.
I just purchased a multimeter and hooked it up to the recharged battery with the following results:
Switched off - 12.4
Running - 12.17
Running at 5k RPM - 12.05
Does that mean the regulator/rectifier is ok?! I've read to check connections and stator but I wouldn't know where to start with checking connections.
Any advice would be appreciated, thanks!
Switched off - 12.4
Running - 12.17
