Well i have read lots about this problem with many different bikes, Problem is i have not found any of these people have found a cure for this...
When you give it a little snap on the throttle the bike is ok for a bit then all the sudden starts to act up and stall mostly if you back off the throttle. or when clutching and then it runs like junk spitting and backfiring..
I have a Hindle slip on and a K&n air filter installed, I have raised the idle like it says in some post and this does nothing but idle higher ( before or after this problem occurs). For the most part if you are gentle on it and never drive the slightest bit hard it happens less frequent.
If you do any driving (besides driving like miss daisy) this problem will eventually happen.
Can someone give me a cure for this????
