1 - 16 of 16 Posts
So my k7 won’t idle/Crank I have no code. When I put it in dealer mode I get c00 which means no code so I’m lost. Any help!!!!
What happens when you hit the start button? Does the fuel pump prime when you turn the ignition on?
Yes the fuel pump primes when I hit the start button it just turns over and tries to crank. Sometimes it will and rpms jumps around even while holding the throttle but eventually turns itself off
Any other work to the bike? Have you removed the airbox? Have the cams out? Sounds somewhat like a vacuum leak so I would recommend checking the IAP hoses, especially if you had the airbox off.
Yes the air box has been off. The throttle body has been off and the rectifier has been replaced do to plug melting between the rectifier and stator
Yes actually it stopped running when the stator/rectifier plug burnt up so I straight wired it.
Discussion Starter #10
So good new my bike started but didn’t last long. It’s a plug on the side of the throttle body that hangs on like a rail. When I unplug it the bike runs and idle but RPMs aren’t over 6k. When I plug the mystery plug back in the bike shuts off. The plug I’m referring to leads into the back of the throttle body underneath the fuel rail. Is there anything I’m missing
2 resisters in the ignition cylinder if they dont line up the fuel pump will not come on fix your wiring then turn your key to the on posititon ,i just lost my key and thought i could bypass it , you can power it up but the pump wont come on its in the ignitionn!
You are correct but if it was the ignition/wiring, it would show a C42 fault code. He said he has no codes.
Sounds to me (and this is really just a guess) like you have the TPS set wrong. I think you mentioned that you took it off?
1 - 16 of 16 Posts
