21 - 24 of 24 Posts
Administrator
Don't give up yet, check the valve clearances.
This is where a leakdown test comes in to find out where the air is leaking. My guess is exhaust valves since you don't mention lots of blue smoke or oil consumption.
Reactions: Mquinones94
Discussion Starter · #23 ·
OK so I put the 750 in I change the airbox throttlebody speedo and the ECU now I’m having a new problem the bike starts up just fine sounds amazing but when I go to takeoff it is very jerky. Can’t rev past six K if that and also no misfire or popping sounds like it’s running fine the fuel pump is brand new and filter you guys got an ideas on what this could be i ain’t getting any codes new engine was fully tested before instal so since i know its not the engine what else could it be?? TPS??
Solomon's decission! My Congrats!
Did you change injectors to 750cc? I don't sure they same as for 600cc.
21 - 24 of 24 Posts
