1 - 16 of 16 Posts
Hey guys,
Just purchased a 2019 1000x model and am trying to figure out how to convert this to gp shift. I have done research on this and it looks like the 2017+ models you just have to flip the knuckle 180 degrees but this thing will not slide on.
I’ve done this on multiple bikes and it slides right on like butter regardless of angle. When I try on this bike like all videos and posts show it will not slide on the shaft 180 degrees from standard position? In the regular position, there is a good 30/45 degrees of rotation where it will slide on and then it stops and will not engage?
I even tried taking off the rod and flipping just the knuckle and still nada? Any help you guys can give me is appreciated. Thanks
Did you take your set screw completely out of the clamp?
This bike is not a direct transfer of 180 from the stock (Standard shift) position. The clamp arm is angled and when reversed the teeth along with the clamps arm put the shifter the wrong position.
It took me many try’s to get this switch correct Even with my normal methods of:
mark the Toe height to the right on the frame, mark the “split” part of the Clamp on the rod that goes to the shift drum, and measure the distances of adjustment at the top and bottom of the shift rod. All of this is so you can go backwards if you mess up.
once you remove the clamp make sure your shifter in the same spot, rotate the rod and flip the clamp around. The biggest challenge being the offset arm and grooves. The goal is to get an even shift up and down.
I can send a pic of mine if you need.
I thought they all just rotated and slid on. Are the splines symmetrical all the way around? Any burrs on the splines?
Should be 180 with the arm facing opposite and the shift rod adjustment but I found this model to be very challenging
yes a pic would be great, I’ve tried all sorts of angles from the other side and it will not slide in. I’ve tried lubeing it as well but it isn’t happy or wanting to slide in and don’t want to force it.
If your having trouble getting it back on get a rubber mallet and tap it a few times or try PB blaster.
Discussion Starter #10
No burrs or damage on the knuckle or shaft. And the pattern appears identical on both parts so either side should work it just isn’t happy sliding
Take the bolt all the way out if you need to use a small wedge in the slot not to much you don't want to break or crack the arm. slide it off rotate it 180 deg reinstall put bolt in torque it you're done. Also you should not have to use a mallet or hammer for this project.
I may have run into your problem which is why it took me an hour, can’t really remember. Try rotating full circle to see if it slips on anywhere.
Discussion Starter #14
Just tried the wedge and really cranked on her as safe as possible, went on maybe a hair more but still not even close to getting past the first teeth. Did try the full 360 and the only side it wants to smoothly and easily slide onto is the left side aka standard shift side. I feel the same on the mallet, even if i get it on there i will need to take it off and move it to adjust the angle to get it right, for sure dont want to tap it home. Im going to take her to the shop and will let everyone know what the outcome is. pretty crazy im even saying that lol.
thanks all!
That's strange, unless they have made more changes to it to try and keep people from switching to GP.
My 2011 GSXR 1000 had the procedure for switching to GP shift in the owners manual but these new bikes don't so they might not want to condone it anymore.
Have you checked the splines to be sure they’re not damaged any way. And that they’re the same ie there is no master spline all the splines are the same (symmetrical splines) I can‘t imagine them not being. I think you must be over looking something.
1 - 16 of 16 Posts
