mannydaze said:
I have a Y2K GSXR 750 that often stutter steps when accelerating in 2nd gear. It generally occurs once per ride. It slips and grabs(thats what it feels like) so quick that I cannot identify if the rpm's increase. Any ideas????Thanx
Here's the list of parts U'll need to get it fixed..
www.ronayers.com
09280-08012 O RING D:1.9 ID:7.8 (7)
11482-35F00 GASKET, CL COVER (1)
11489-35F00 GASKET, OIL PAN (1)
14181-46E00 GASKET, EXHAUST PIPE (4)
16510-34E00 FILTER ASSY, ENG OIL (1)
25211-35F00 FORK, GEAR SHIFT (2)
25310-35F00 CAM, GEAR SHIFT (1)
24361-35F00 GEAR, 6TH DRIVEN (1)
09380-27006 CIRCLIP (3)
24321-35F01 2ND DRIVEN GEAR (1)
25510-35F00 SHAFT, GEAR SHIFT (1) *
You might want to use part number *25510-35F01 instead of *25510-35F00 (gear shift shaft) since the new part is solid. I would order 6 of circlips instead of the recommended 3. I believe they are all the same size.
:thumbup:
