520 chain is narrower than the 530 chain so therefor lighter in weight, if you go up 3 teeth on the rear,you are moving the rear wheel forward quit a lot, you could go 1 down on the front, which would give you the same gearing, and your rear wheel would go backwards very slightly, and transfer weight to the front, I would recommend you put a 2 tooth longer chain if you are going 2 or 3 teeth up on the rear.
