1 - 3 of 3 Posts
my lights worked the other day now front lights won't work at all u no wat mite be the problem
Just a guess, but there is a connector between all the lights in the nose and the main harness. The ground wire connector has been a common problem. It is the black with white striped wire.
My K7 750 was/ is doing the same thing. Identified the problem as the starter button, it breaks the headlight circuit when the starter button is pushed to reduce battery load when starting ( i think). I don't know if the srad is the same , but you can check it by turning on the key and "wiggling" the starter button up and down. If the headlight goes on and off, the switch contacts are probably sticking, my $02 worth.
1 - 3 of 3 Posts
