No its not, its for Fuel injected bikes, becuase if you had carbs, then you would have no need for the power commander. If you know anything about carbs, you will know they have an accelerator pump, which gives you a little extra shot of fuel when you stomp on the pedal, the accelerator pump program for the PC does the same thing with your FI. So if you hit WOT quickly it will give you a shot of fuel to compensate for the extra air.
