Meant to add, tried another ecu and ignition and still no joy.
Is the tip over sensor able to trigger the Chec code?
Yes and got another one with the other ECU for the pairingJust a random thought, do you have the OEM ignition barrel fitted?
There is no Orange yellow according to diagram.Possibly. Check the orange/yellow wire from ignition to ECU for continuity.
You are not the first to do this, it is rare but does pop up at times. I think the other connector is for the secondaries?Ok. Could now have identified it was me putting wrong connector to fuel pump. There are 2 identical connectors under the tank that will fit to the fuel tank.
Good news, Chec is gone. Now getting FI and Sd.
Battery on 12.4v due to all sitting and cranking so charging that first. Failing that need to look up bridging the dealer switch to get the C00 code.
Once again thanks for all the assistance.
Doesn’t help that the one you need is wired lower so can fall down but the other is linked to the secondary throttle and naturally sits near the plug on the tankSilly design putting identical connectors that close together![]()
