I have bought a new set of rims with new tire on them. So all i have to do is take the old ones off and put on the new rims and tires. Do i need a special tool for the front axel? Let me know if you have any tips or heads up on the install to make it easier.
thanks again
brian
thanks again
brian
hi! he exist a jack call bull dog for the front its easy to use .
thanks again
brian
What year bike do you have. If its a 00 then I know that is takes a 24mm front socket to get it off. If its 01+ then you need a 17mm(i belive) allen wrench. Motion Pro makes a tool to get the front axel out, its like $20 I think.
Yea, your going to need to lossen the pinch bolts on the right side only(sitting on the bike) and then remove the 4 caliper bolts, and the you can loosen the axel with a large allen wrench.
