they feel like cracks and there was a little bit of oil on the bottom of the filter but I was able to turn it 1/8-1/4 more of a turn so I can't tell if the small leak was a loosened filter. It is the line at the bottom
Tire Wheel Automotive tire Flash photography Style
Where the casings fit together? Is it leaking?
Administrator
I believe those are just casting marks. I've never seen or could come up with a reason for it to crack in that area.
Your loose filter was probably the reason for the oil leak. Clean up the area well and check it again after the bike gets warmed up.
Reactions: Todd_Sails
Administrator
That is what I was looking at.
