41 - 44 of 44 Posts
Discussion Starter · #41 ·
This is easier shown than explained... but here it goes.
Get 2 nuts that will thread onto the top portion of the stud. Tighten those two as hard as you can against each other not down to the base of the stud. Then hold the nut that is on the bottom of the top portion of the stud with a wrench and use your ratchet to break that bottom nut loose.
Soaking the bottom nut in a little bit of PB Blaster 30 mins before you go at it can make a big difference.
That sounds like a good idea. i'll give it a try.
Alpha Canuck
At this point I am leaning towards taking a dremel or angle grinder and grinding one side of the nut off. That will do it and is easier than trying to get cut off wheel between the nut and the faring stay. Grinding one of the flat sides of the nut down to the threads of the bolt should leave enough nut to get a wrench on if you need to later.
41 - 44 of 44 Posts
