alrite guys i have a problem. well i got the rotor and calliper on and then looked where to run the brake line. are both brake lines run from the master cylinder up top to seperate callipers or what. my friends r6 is run that way. we were thinking that i could put the banjo bolt with 2 holes on one calliper then run the shorter brake line over the front fender into the other calliper. is that wrong. the guy gave me the extra rotor, calliper and line. so i dont know how its supposed to be run. can someone tell me or post a pic of the front of a bike. thanks
so he gave me the right brake line? i use the double holed banjo bolt on the calliper then run the shorter brake line over the fender to the other calliper.
yea, one line down to the right caliper, then the second line runs fron the right to the left caliper.
Are they stock lines... if so what these guys have told you is right. If they are steel braided most of them run like your buddies R6, two from the master on to each calliper.
