I've concluded that I need to replace my head bearings (Front wheel vibration on heavy braking.) and looking at that job now.
I have the manual and it says the first nut goes to 45Nm then the lock nut to 90Nm. I am sure it doesn't 'need' that because I have already tightened up the nuts before, for slack, with a drift and hammer.
But, to apply 90Nm, to do it properly, I'm planning to bite that bullet and buy a tool to do the job.
£20 for a socket, or £10 for a long 30mm c spanner. I think 90Nm on just one detent of the nut maybe too much for it, seems to be an aluminium nut.
Sigh.
Why didn't they just use hex nuts? I'm looking to see if I can get 5mm thick M24x1.0 hex nuts for less than the tool! Is that wise? What is the point of having a castellated nut like that? If the idea is that you can adjust without removing the top boss, that's silly because then you can't apply 90Nm to tighten it, even with Suzuki's own tool?
Am I missing something here. Suzuki, why not give us hex nuts?
Sigh.
