I have an 07 GSXR 750 with the C46 code flashing. I've been reading up on it and I'm not sure what and how to check if it has to do with the Exhaust Control Valve Actuator or the SET valve. When I turn the bike to ON the EXCVA motor turns on and moves and I don't know where the SET valve is so I'm not sure about that. I just put on a Jardine GP1 slip on exhaust but I never messed with the EXCVA. Any and all information would be great.
Thanks.
I'm not familiar with the newer bikes cause mine is an 01'1k, but you should have a valve on your midpipe, and one on the throttle bodies. I know on mine when you disconnect the set valve, you have to unhook a wire so the comp wont trip.
Hopefully someone can help you more, good luck.
