1 - 12 of 12 Posts
Hi guys
I have noticed that at deceleration I have this massive rattle...could it be that this engine has longer chain fitted? Thanks
Sent from my Redmi Note 9 Pro using Tapatalk
I have the same bike. It seems to me, when I ride, it seems to have some type of rattle like a tambourine sound LOL.
I have a MCCT. and try and keep in snugged up too. At start up and listening w/o dear plugs in, it sounds fine. Runs well. My magnetic drain plug is always clean too.
Maybe a video of the 'rattle'?
Let's see if you can hear it to me it's a looot more than my other k6 I turbored (when engine was stock was almost not there)
Today I pulled the stator cover and the part(magnetic) keeps on catching a lot o metal dust...I don't know if this is normal, I did a rebuild
New crank and rod shells, thrust bearings and piston rings.
It quite some build up.
The casing after cleaning looks like this
Wood Urban design Brick Road surface Gas
Motor vehicle Automotive exterior Gas Engineering Mass production
Disregard the last one it's a vcds read out
What one have you installed?
Which manual CCT? It's an APE knock off, that is even stamped w/ APE on it.
It works fine.
I'm not so sure it's your CCT however.
You know more and do way more to these motors than I have ever done.
Discussion Starter · #8 ·
It works fine.
Where can I get it? Thanks
Discussion Starter · #9 ·
I will try anyway, with a manual ct I think it's a win
IIRC, I got if off Ebay? The MCCT Yours looked pretty snug in that one video?
Discussion Starter · #11 ·
Yes, im starting to think that the chain is too long...maybe not the correct one...this engine had 5 previous owners never Gona know what they have done
1 - 12 of 12 Posts
