1 - 2 of 2 Posts
What I want to know is how can you tell when your chain needs to be tighened, and if it does how would you do that on an 02 gsxr 750. :arsenal
You have to check the chain tension, by seeing how much the chain moves up and down. It should have about 1 inch of freeplay. The way to adjust it is with the chain adjusters, they are the bolts that push against the rear axel, you have to loosen the nut on it then screw the bolt in or out depending on if you need more or less slack.
1 - 2 of 2 Posts
