Hi guys new member here looking for some advice from u guys .I had k6 and k7 600 before and cant remember if they done the same thing but here is my problem or could be normal
While coasting/rolling in gear with clutch pulled in .if I give the throttle a rev will still pulling in on clutch I'm getting a little noise like something is lose or clunk only while rolling in gear if it's in natural or standing still and I blip throttle it doesnt do it ..iv just had everything checked at the shop and he adjusted the clutch and chain everything seems perfect and changes gear like normal ..
Personally, I've never done those things. Just never had the need to rev the engine with the clutch in and coasting in gear.
That being said, I'm guessing you are hearing the transmission dogs clunk from one side to the other.
While you're coasting at idle, the clutch plates are being driven by the transmission. When you rev the bike, my guess is that clutch drag is now causing the transmission to be slightly driven by the engine and the transmission dogs move to the other side of engagement.
If the OP is doing as described, it would produce a clunk. I don't see and issue.
Like the old saying "Doctor it hurts when I do this" "Then stop doing that"
