just got suzuki gxsr 2001 600 and I see coolant in the oil what do I check first or what can be the problem
it’s green in the clutch cover I got the clear one so you could see in itWelcome to the forum.
May I ask why you think you are getting coolant in the oil? Is the oil way over full and the radiator low on coolant?
If that is really coolant than it could be a worn seals of the water pump shaft and worned/rusted pump shaft under those seals, I think.it’s green in the clutch cover I got the clear one so you could see in it
Drain the oil first and see what you actually have. If there is coolant in the oil, you will clearly see it separated.it’s green in the clutch cover I got the clear one so you could see in it
oil mixed coolant - Google SearchThe second reason is that coolant does not just sit there, it mixes with the oil and makes a latte like creamy brown mixture.
Oh yeah, been seeing a lot of that recently on some John Deere engines I work with - oil cooler O-rings failing.
I changed the oil…and the it had coolant in but it wasn’t like mud I just like oilDrain the oil first and see what you actually have. If there is coolant in the oil, you will clearly see it separated.
The reason, i'm poking is that this time of year lots see moisture in the oil due to the cold and condensation.
Ahhh. I guess it has not been run with the coolant in the crankcase.I changed the oil…and the it had coolant in but it wasn’t like mud I just like oil
I empty the oil pan again fill the coolant it just need a little coolant but nothing came out I think it does when I drive the bike not when sittingAhhh. I guess it has not been run with the coolant in the crankcase.
Was the radiator empty?
Spontaneous oil in the coolant this time of year is usually because the engine froze. Was it out in the cold?
With the oil drain plug out, refill the radiator and see if and how quickly oil comes out the oil drain.
Could you put some photos of this one why you decided that be an oil with coolant?I changed the oil…and the it had coolant in but it wasn’t like mud I just like oil
