07 GSXR 600 new rider
Got the bike with zero problems took it pretty hard ride about 100° out never ran over 220oil temp. Stop to fuel up notice that was leaking green fluid found out it was coolant got home took the faring off check my coolant level is right under the bottom line. I don’t know what kind of coolant was in the bike before and I’ve heard some things about mixing coolant I went out and picked up some engine ice just to top it off I was wondering if I need to flush and bleed or if I can just top off
You can likely top it off with coolant. Check your specs to match the right kind. In reality if the bike is new to you it is good practice to flush all fluids and start fresh. Brakes, oil, coolant.
You might want to investigate what's causing the leak. If it's the overflow, possible your radiator cap is toast.
