when moving slowly, clutch engaged, not braking...
I can't really tell where it is coming from, is it possibly my chain too tight? I really can't move it more than 1/4 up and down. I think I read that it should move more, but would this make a crunchy sound like I am hearing?
Yep sounds like the chain and the play on it should be about an inch so sounds like yours is to tight. I will also make that noise when it dose not have enough wax on and when its worn out and needs to be replaced.
I just got the bike almost 2 months ago. If the chain is original, which it probably is, then it has 11k on it. It's time to replace it? Or should I just loosen it and check for play?
