i have found that when you look up the part # if it is the same then it will fit....
if not then you may need to find some spacers or something, because the hub maybe a dif size
Discussion Starter #6
im using the wheel from a 1k because its what i have, i dont have the wheel for the 600 and dont wanna spend $600 on a wheel so i wanna see if i can get the 1k to work
Did you ever figure out an answer for this? I wanted to put a 1k wheel on my 600 because its wider and looks better, how did you work this out
