1 - 2 of 2 Posts
does anyone know how to use this program? any experience with it? does anyone have any custom maps? if i get the timing retard eliminator will it be pointless because of the power commander? thnks for the help. :thumbup:
If you get the power commander go with USB version as its alot better and has some features that you can add to it now maps are available thru the www.powercommander.com Getting a map from someone because it work for them will not mean it will work for you. These maps on the site are usually okay but not specified for your bike. If you are really wanting to take advantage of what you spent with a power commander you should by the Powercommander as well as a dynotune and then you will have your bike at its best. If your near a dyno shop try to get a run as your bike is and then when you add stuff to it such as pipe or so get another dyno and see what it is doing for your bike. Dynotuning in ranges in the 200-350 range,but a dyno run could be 10-15 bucks
OH yeah you can say power commander for short versus dynojet power commander as they are the same :cool:
1 - 2 of 2 Posts
