1 - 8 of 8 Posts
Does anyone know if an ECU out of an 02 gixxer 1000 will work on my 04 1000? I'm trying to part swap to eliminate the ECU as the problem. I'm pretty sure that the 03 will swap over but living in a somewhat remote location has me limited to what other bikes I can find for trial swaps.
The 03 & 04 models show to be part #32920-18G20
The 02 shows to be #32920-40F30
I know I had a 00 gsxr 750 last yr, I was trying the same thing part swap to figure out a issue, I wound up with 3 computers all belonging from 2000-2005 ,2000 , 2001-2003 and 04-05 have slitely diffrent part numbers. Each computer ran my bike the exact way my Ecu was not my issue I’ve also heard about many guys swapping computers from slitely diffrent bikes diffrent numbers and having no issues, the most bazaar to me I heard a guy had a 07 750 with a 01 computer and drove it every day no issues. I still have 2 750 ecm’s im considering plugging it my 06 1000 to see if it works bc I would like to send my 1000 computer out for a flash. If any one has any exp. let me know
You would be better served sending your ECM to someone with a good running bike to see if it then shows the same issues when your ECM is installed in their bike.
If it doesn't, you have a different issue with your bike.
Discussion Starter #6
It sounds like the smart way to do it, my only problem is that I don't know anyone that I can trust to send them my ECU to and expect to get it back.
No, the '02 and '04 GSXR1000 ECU's are not compatible...
1 - 8 of 8 Posts
