I have an 07' 1000 and I just put Galfer SS lines on it but this problem was there before. I start out and the front brakes are not real solid, the lever isn't spongy(spongy isn't the right word but best description) but it comes back half way to the grip. As I ride a little bit the lever will become more "solid"(can only pull it in a little bit before it starts to brake) and the brakes are awesome. Then they will go back the other way. There is no consistancy to it, just seems to fluctuate back and forth for no reason. Any help? I have bled the system over and over, bled the master, bled the calipers again.... no change. Is the master going bad? I have no fluid leaks, no fluid anywhere, cap doesn't seem to be leaking. Mind you, the brakes are not bad to begin with, they stop fine, everything is good. They just go from good...to great!! I like the lever a little harder(solid may be a better word), and it goes from a little spongy(spongy isn't the right word but best description) to being solid and then a little while later back to being a little spongy. I have new lines, new fluid, new pads, 14K on the bike and clueless as to what to check next.
Thanks in advace for any help!!!
